will i hav any clearance problems with the factory ac or will i need to move the ac?
notch the frame or move it up high.
do you gotta notch the frame alot?
hopfully i can get trans swapped out this week or next
pcm? what fuel pump/filter did you run on yours.
imma switch to 87 tank just gotta find a good pump and still get instument cluster tho
I am using a walbro intank pump, forget model #. Using the vette filter/regulator.
Check out 67-72trucks.com, several swap, and a few who notched frame for a/c...
I did not so I can't tell you how much.
Good luck.
alright thanks
i remember you did sorta same swap but had 4l80
I "hear" brp has a swap kit that allows you to keep the ac down low without notching, but I have not seen a truck with their kit.
http://www.brphotrods.com/Truck%20LS1.html
call and ask for Phil...he should be able to answer.
ill probay just notch it tho.
figure tha part out wheni putit in i guess.
