Quote:
Originally posted by kinjo1977@Dec 28 2004, 06:44 PM
Even with a locker they spin? Sounds to me like you need to get a Eaton posi.
But as far as the track goes, these won't ever be going. I got these mainly for daily driving. Its odd though that they are not working well for you, they were ranked with having some of the best traction on the market.
Yeppers, on the last pass I was loaded up and was going home they only sqeaked a little off the line but that was w/ 300 some odd extra pounds sitting over them and still on 20psi. I also noticed that they are a harder compound as the tread rating is much higher than my old tires 500 treadwear vs. 300 so they should last a long time. Also my observation is that the contact patch is smaller than my old tires even though they are the same size. This could be the factor in the traction issues, and the sidewalls seem to flex more when cornering at speeds. Again this is my opinion, not flaming on your tire choice just stating my experience w/ mine. I'm glad to see you are having good success w/ yours. :hshake: Also what pressure do you run at when driving,cruising, etc ???
