what do you guys think is better...a shift kit, or higher trans pressures with a tune, cause ive heard you cant have a shift kit and have a trans tune
You probably can, but I've hear that turning up line pressure through a tune is not good for your solenoids.
Everyone on here talks about transgo all the time, but I've been in trucks with b&m, and it works just fine.
i have a transgo HD-2 its up to you on what you wanna buy.
get a seperator plate bc your stock one is thin an is probably worn out.
shift kit, servos, leave line pressure stock imo. im not a tuner..just going by what i was recommended
Go with the Trans-Go. They can be found for cheaper on Ebay. when installing shift kit, go with the softest shifting stuff. Drive it around and see if the shifts are too hard. If so, have your tuner back off shift pressures.
