The truck is a 2003 silverado w/ 5.3L z71 4x4 extended cab. It has a 6" pro comp lift with 3" body lift. 37" toyo mt's on 20" weld racing rims. The turbo set-up is an sts kit with garret 60/81 turbo, 44# injectors, sts meth kit and predator programming, I run 5psi daily and 9psi w/ meth on electronic boost controller. Motor rebuilt and bored 30 over with better bottom end and upgraded valve springs and push rods. Rebuilt 4L65e tranny with billet input and output shafts. Rear end is a custom fabbed 14 bolt w/ 4.56 gears and eaton locker. For car audio I have the avic n4 head unit with Navigation and DVD, two 12" eclipse subs in custom enclosure with a jbl 1200 watt amp.
So far I love the site and have received very needed help.
Thanks guys!
