What nos setup should i do for my stock 4.8 that would be safe to run without burning my stuff up, all i have are bolt ons right now saving up for an sts turbo
If ur gonna go turbo, you'd be better off with a methanol system rather than NOS.....unless you can afford both
Run an easy 100 dry shot.
^Agreed, they're quick, simple, easy to install and when you do go turbo and don't want the nitrous anymore you can sell the kit and probably not lose your shirt on the deal.
jetmech your truck is my hero! btw
I would get a basic kit. You could do dry... but I like wet kits. Like a 78mm plate, and a reg 10# bottle. Make sure that if you do a dry kit, that your injectors can handle the extra fuel thats needed. I would run a dry shot if it were a smaller shot. But wet is generally safer. Any Ls1 plate kit can work. About any nitrous kit will work. Just get a kit with a window switch, WOT switch, wideband a/f ratio gauge, bottle warmer, and nitrous pressure gauge.
whats a good website to get a good kit for my truck
ebay.
