Some gaskets don't have a cut out on them for this vent hole so you have to trim the gasket around the hole, sometimes people will used silicone on the pan and block the hole. If it is blocked the band won't work correctly. The band is applied in 2nd and 4th. It may or may not be the problem but it might be worth a shot to check it out.
http://www.ls1truck.com/upload/files/51/vent%20hole.jpg
