hey guys i need a bit of help. my ecm on my truck will read my maf sensor and then some time lose it. i already replaced it twice and put a new connector. i troubleshooted each wire back to the ecm and the the fuse(eng1),thiers is no open circuit on the wires.is their anything else that can be bad. i believe that my ecm is going bad. last week when i got it retune the sensor was not sending a signal to the hptuner i had already replace the sensor two week prior. so we replaced it again and it started to show up on the tuner. but the next day before i headed to the track check engine light came on again. checked the codes an it was the maf sensor again. po102 is the code its giving out. can it be a bad ecm or something else. thanks for help.
