Direction Im heading..Advice needed
Well I figured since Ive been researching and investing in new parts and what not Id figured I would ask a few questions. I am going the Spray/ N/A AWD route and have a good hookup on a head miller/porter in town who does a great job.
What I have:
-5.3 with 216/220 .525 .532 114 Comp Cam part # LS1 XR269HR-14
-7.4 Comp Pushrods
-Beehive Springs good for .600
(All the above installed 8000 miles ago into a 07 5.3 with 55k miles; used to have a 4.8 in my 06')
-All bolt ons and what not
Parts need to install & laying around:
-1.75 Scorpion LS1 Rockers
-Bare 853 Heads, Going to Port, Mill, and do a 3 angle valve job on them
(Where is the best place to get good valves and seals for these?)
-MT E/T slicks on 15"s :naughty::naughty::dancenana:
-PLX wideband
Want to get:
-LS2 TBSS Intake Manifold and 90mm TB with Dr. X Harness + injectors (Should I get 42lbs? for boost later?) or what size?
-LPP LT's and ORY
-ZEX or Nitrous Outlet Dry Kit probably a 75 shot on street and 125 strip rarely of course (On a budget and want to keep simple)
-ARP Head and Rod Bolts
-CTS-V Lifters (They are said to be quieter and stronger)
-Ported LS6 Oil Pump
-LS2 Timing Chain
-Nitrous Pressure Gauge
(Where can I find a digital one of these and not one with needles?)
Basically now that I have a daily driver, (Got my old v6 01 camaro back :dancenana:) Im going to go into hardcore mode with the truck, but leave it N/A when this project is finished and be done with it till after college when I can get more into it with boost and what not. Does everything above look good enough to get me to around 380-400 ish rwhp on my 5.3 and be safe and secure? Anything else not on the list needed? The truck has been daily driven but in a month or two that is going to change to just weekends or barely ever since I want to keep the miles off of it.
I am going the AWD route and want it to be a street/Strip truck, the truck is a 2wd right now, but the AWD conversion is in the works.
As for the bare 853s I have, Im sure my porting/milling guy will know what to do but do I just need to mill them .30 and do a light porting job? Or should I get them spec'd professionally and give the specs to the guy?
Any advice yall could give would be great! I am still in the learning process! :p
