Problem with LS1 electric fans and harness
I installed LS1 electric fans and am using a blackbear harness which I believe is a copy of the Nelson harness. Anyways, I got it hooked up and all I am getting is the passenger side fan running on high all the time? The driver side fan never comes on. I verified that the pin is correctly installed in the harness. I spliced the green wire into the solid green AC trigger wire in the loom next to the junction box. My A/C works as it should after the swap. I switched the connector from the passenger fan to the driver's side fan and it came on high. So I know that my fans are good. Any thoughts? Thanks
