Originally Posted by
PedaltoMetal
I'm in the same boat as you only I'm running DBW on an 03 LM7/L59. So no place to hook the T.V. cable. I've be wanting to go FMRVB anyway so no biggie. The dished 5.3 flexplate and a spacer will work but you'll have to "modify" the bolt holes since the 700r4 converter is 2 mm smaller in bolt circle. 298mm vs 300mm. Unless you get a custom converter. Advance adapters sells a kit if you want to go the bolt on route.
So my plan is to run a manual tune DBW set up with the FMRVB 700r4 and the TCC on a switch in my 83 K5.
btw 700's can be just a strong as 4l60/5's
