Water pump help
ok everyone. im replacing the water pump in my 03 SSS
I was checking out the situation before hand and noticed this
http://farm3.static.flickr.com/2567/...369547641a.jpg
its at the top of the water pump, right under the TB.
Now, on my replacement pump, I do not have such a hole..
http://farm4.static.flickr.com/3445/...a04391a39e.jpg
can anyone advise?
mike are you talking about that ''gap''?
Generally that kind of thing can change when it is a cast part, because engineers are always looking to make the casting and casting process more efficient. If it does not fit then it would be a problem, but i think that the replacement water pump manufacturer found a better way to make the casting, plus with continuous shapes they are much stronger than castings with pointed or sharp edges.
no i was talking about that bolt that faces backward.. turns out its a plate that covers the impeller.. new pumps dont have that.. i got the job done.
