Guys,
Need help with this procedure, cant do it with my HPTuners, Cause it says not ready ECT low.
the temp stays at 92 F, but when I start the scan, it reads the correct temperature.
Someone knows how to fix this problem?
Guys,
Try a TechII.
is the engine low on water? That's like you have a huge air pocket.
Engine temp needs to be above 140deg, or whatever closed loop temp is, can't remember, but close to that.
A/c off, park, idle stable, sometimes brake on, then it's ready.
But on your truck, it still won't work. We put your truck in open loop due to a faulty o2 sensor, so it'll never get into closed loop. I'll send you a file, remind me tomorrow, it'll be temporary, but it'll allow you to perform the procedure.
156*
Yep, that's it.
