sensors need for the harness
i remember copying this from somewhere and i wanted to see if this is all i needed. does this seem right to you guys that have done this before?
CONNECTIONS ON ENGINE SIDE
TPS THROTTLE POSITION SENSOR
IAC IDLE AIR CONTROL
IAT INTAKE AIR TEMP
CTS COOLENT TEMP SENSOR
MAP MAINIFOLD ABSOLUTE PRESSURE
CAM CAM SHAFT SENSOR
CKP CRANK SHAFT SENSOR
MAF MASS AIR FLOW
4L60E TRANSMISSION CONNECTION (DEPENDING ON TRANSMISSION TYPE)
VSS SENSOR
KNOCK SENSORS
BOTH FORWARD RUNNING O2 SENSORS
BANK 1 AND 2 OF THE COIL PACK CONNECTORS
INJECTORS 1,2,3,4,5,6,7,8
CONNECTIONS ON PCM SIDE
RED AND BLUE 80 PIN PCM CONNECTIONS WITH RETAINING BOLT
ALDL OBD2 DIAGNOSTIC CONNECTION
POWER RELAY
FUEL PUMP RELAY AND PUMP CONNECTION
SERVICE ENGINE LAMP CONNECTION
TCC BRAKE SWITCH CONNECTION
SPEED SIGNAL OUTPUT CONNECTION
