4L60E slipping
ok.......yesterday i decided to change my atf since i hadnt done it in a while...transmission was running great til after the change....changed the fluid and filter..didnt drain the converter or anyhingjust the contents of the pan..used a respectable wix filter and multi purpose dexmerc fluid....well left to test run it down the road it was fine under normal load...if i laid into it would slip...ok figuring it might be a lil low i went back to the shop checked the fluid again and come to find out it was bout a quart low...put that in and test drove it....got better through out the drive home...took a 180mile drive today and seemed good til i figured i mess with a lightening.....she downshifted and slipped again...but was like i was in neutral.....checked the fluid again and it seem like it should have been ok...the level was at the bottom of the hatch marks...havent done anything yet....local shop says it should be 5 quarts for the pan...put 5 in and still slippin....i aint no mechanic...but like to do my own works....done this before to this truck and didnt have a problem....any ideas!!??
thank you in advance!!...its appreciated
trevor
It needs GM Dextron VI and nothing else IMO. Parts store FoMoCo or Dextron/Mercon fluid goes in a '69 Chevelle....not one of these.
thnk you very much...this slippin was gettin on my nerves...my manual got shredded so i had no way of tellin exactly what to use...so i went with the auto zones recommendation...thanks again...lesson learned!!
trevor
Let us know if that helps.
i use oreillys house brand in my built unit and it works great your fluid level is very important make sure the motor is running when you check it.
running in park with fluid warm.
try adding a lucas trans additive if it's low, that stuff does wonders
well come to find out for somehow...some reason the filter had fallen out of the valve body..wouldnt let it shift like it was supposed to...dont understand it but thats what it was...for s&g's did a flush to get everything this time and she good as new...thanks again!!!
trevor
We sell Dexron VI at Autozone, wondering if the Mobil 1 or B&M Hot Shift would make any difference in a fluid change. It is expensive.
