Catch Can?
Hey guys i have a bit of a problem and need help. on my engines passanger side valve cover i have open breather drivers side i have a cut out pcv so its wide open with a small breather as well. My problem is im blowing oil out mainly on the passanger valve cover filter.
I've been looking into catch cans but all say the same does anyone have any recogmendations on which to go with. or what route i should take care of this situation?
Thanks Ray
v
v
v
my engine setup is in the video
__________________
How much oil are you blowing out? If it's a lot, you may have other problems like a broken ring or ringland. Otherwise, you could get a catch can that has a breather filter on top of it.
catc can
it was alot when i put a filter on the pcv valve with no vaccum but since i cut it out its not as bad but still got blow by on passanger side..
lsxvideo - Nitrous LS1
