I am puting a 6.0 vortec in my truck. I am planning on using a set of cnc ported l92 heads. Could I get these power numbers with the factory intake and injection sytem?
stock truck intake will definitely be getting in the way at high rpms.
cam and bolt ons with those heads and a good intake should net you 500 on motor.....possibly.
stock injectors, no
what about with bigger injectors?
right size injectors, good heads and high comp. and you could do it
I would say match port the intake too that way you get full benefit of the heads
alright say 10.5:1 comp with the right cam, bigger injectors and maybe a little porting of the intake then 500hp would be possible
Thats a close call. Depends on what cam. I would say at least a 230 duration 560 lift cam. If you could get a smaller combustion chamber to get you closer to 11:1 that would be a for sure 500 horse motor.
