converter swap in a 4x4 truck/suv
Basicly what is involved? I crawled under the yukon the otherday to check everything out for when i throw on the longtubes and stall and was thinking about removing/rolling backwards the trans/transfercase. However the xmeber or whatever you call it that the torsion bars conect to is in the way from alowing me from just pulling everything towards the rear. Do i need to just drop everything straight down? Ill be using ramps/jackstands on gravel with plywood mostlikely. Thanks
