Well, I finally got the heads on and then did another compression check. Number 7 piston is still loosing compression somehow. I'm sure it's not the gasket anymore, it's reading the same amount of psi, 50.
The only think I can think of is the ring or piston is damaged. It wasn't making any knocking noise (before I tore is down) or smoking, so not sure on this one. I guess I'll pull the engine and check out that piston. The heads looked fine.
any ideas?
btw, are ARP studs reusable? Those bastards were $200+ and they better be, lol.
thanks,
allen
