LS engine swap info needed
I`ve got a 90 chevy K5 blazer and I`m thinking of swapping a 5.3 in it. THe TBI 5.7 runs great but has 227,000 and I figured if I did my research and found out exactly what i needed for the swap it would ether run about the same or just slightly more money than rebuilding my long blockor buying a new long block from GM. I see 5.3`s all the time with fairly low miles complete with all the accesories and harness and ECM for a fair price. I know I`ll need the adaptor motor mounts and the converter spacer so I can reuse my 700R4 and I know I`ll have to hve the harness rewired and the ECM reconfigured but am I missing anything else? Being tha my blazer is a 4wd will I have any clearance issues with the oil pan or exhaust? Can I adapt the later model Y pipe to my current exhaust? Thanks
