wiring and 4x4 switch
can anyone give me a pin out of the connector that goes through the firewall in a 97 Chevy k1500 i have had no luck with it i am attaching pictures
and also how do i get the 4x4 light on the switch to stop flashing when its in 4 the truck is straight axled so there is no actuator on the front diff
http://i87.photobucket.com/albums/k1...7/DSC00560.jpg
http://i87.photobucket.com/albums/k1...7/DSC00559.jpg
I am not sure I can get you a pinout.
But if you are using a harness based around an actuator you can splice togther the two wires that are supposed to connect when the actuator shoud be activated.
The way we did this is we stuck a wire into the actuator plug to pull the connection together as if the actuator was activated and the light fuctions as it should.
If you experiment with it a bit you will get it.
well i have wire that are cut and i need to know what they go to my gauges have no grounds and all of them worked before the lm7 swap and i had someoneelse do the wiring for it and no cant get a hold of them so its up to me now
