Need some help/ideas...can't get any better than 13.7..
Hey guys and gals,
For those of you that don't know my setup I've got a 1991 Nissan 240sx with a 2003 5.3l, stock cam & heads & bottom end, flex fuel injectors (33lb/hr), 99 LS1 intake, true cold air intake (plumbed below bumper), "tune", 99 T56 (stock gears), Monster Stage 3 6puck clutch with 15lb chromoly flywheel, stock 4.08 geared 240sx rear end (welded diff.), long tube headers, true duals, 3" exhaust up to the high flow cats, 2.5" exhaust after the cats, and a Dynotune 100hp dry nitrous setup. And 275/50/15 BFG drag radials.
So, I've been going to the local track since May 1st, between then and now i've added the cold air intake at one point, the nitrous, then the clutch and drag radials. Up until last night i was running on a set of 265/40/17 Michelin Pilot Ps2's. Between all the changes I've only seen tiny gains and always, always run around 14.1-13.8 @ 99-105. I've tried launching in 1st, i've tried launching in 2nd, i've tried not warming the drag radials, I've tried just about everything and can only best 13.703 @ 107.932. Spraying the 100shot last night with the drag radials, i only picked up 2 tenths!?!?!? I was spraying at the top of second once i got traction, then through third and fourth. I'm crossing the line at about 5800-5900rpms at the top of fourth.
Now my father and i and everyone else who's worked on the car are wondering if I'm squeezing the most I will ever get out of the stock heads and cam combo??? or if it's something else? Possibly a better tune? I have no idea but to me I feel with a car that only weighs 2800-2900lbs I should be running a bit better than that *shrug*.
Even with the BFG drag radials, with a good warm up, i still spin through all of 1st gear, and then the beginning of 2nd. Launching in 2nd it just spins for a while then ends up catching traction and pulling around 4500rpms.
I'm out of ideas and hoping that you guys out there will be able to help me out a bit :)
Here's a bunch of my times/slips:
May 22nd (Michelin 265/40/17, cold air intake, no nitrous, old LS6 clutch)
Reaction: .449
60': 2.292
1/8th: 9.237
1/4: 13.970
Mph: 104.289
Reaction: .136
60': 2.425
1/8th: 9.269
1/4: 13.991
mph: 102.393
Reaction: .583
60': 2.521
1/8th: 9.499
1/4: 14.258
mph: 105.475
June 5th (Michelin 265/40/17, cold air intake, nitrous, LS6 clutch slipping bad causes me to coast from just after the 1/8th mile. This is where last weekend and this weekend don't make sense to me at all. The only thing i can think of is i added the new clutch with the lightweight flywheel and maybe i lost some top end power with the lack of rotating mass??? But these times are with the old slipping clutch...)
First run, coasted from literally just after the 1/8th.
Reaction: .144
60': 2.311
1/8th: 9.063
1/4: 14.055
mph: 89.460
2nd & last run, car had a solid 45 min to cool down, clutch slipped again, just after the 1/8th.
Reaction: .294
60': 2.301
1/8th: 8.993
1/4: 13.628
mph: 102.023
June 19th (BFG 275/50/15 Drag radials, cold air intake, 100shot nitrous, Monster Stage 3 clutch w/ 15lb chromoly flywheel).
No nitrous runs...
Reaction: .639
60': 2.467
1/8th: 9.425
1/4: 14.264
mph: 105.248
Reaction: .124
60': 2.194
1/8th: 9.226
1/4: 14.079
mph: 98.973
Reaction: .533
60': 2.241
1/8th: 9.102
1/4: 13.907
mph: 99.050
Reaction: .368
60': 2.341
1/8th: 9.183
1/4: 13.955
mph: 103.298
Reaction: .072
60': 2.351
1/8th: 9.141
1/4: 13.881
mph: 102.972
Now here's the last two runs where i sprayed the 100shot....
Reaction: .303
60': 2.393
1/8th: 9.245
1/4: 13.915
mph: 105.915
Reaction: .449
60': 2.222
1/8th: 9.128
1/4: 13.703
mph: 107.932
So my MPH definitely increased between the non nitrous runs and the nitrous runs which makes me believe that the nitrous is working properly. But I'm still confused...
If anyone's got any ideas or tips or suggestions or anything please let me know...or maybe this is what i should be running and i'm just hoping for too much *shrug*.
I currently have a LS6 cam, yellow beehive springs, 7.400 pushrods and the rest of the goodies for the cam swap, I'm just wondering if I AM maxing out the current cam/heads or if there is something else i should figure out first. I'm thinking it might be the tune too...maybe it's time for a Nelson mail order (there's no good dyno's around here and I'm still weary about doing it myself).
Any help would be greatly appreciated guys..and sorry for the length of the post.
Thanks,
Tanner
