I did my 160 therm last night and found out my 04 has no drain cock, why
did they leave that off? There is a molding on the drivers side bottom but no
cock valve/hole installed. Is this a mistake or are all the 04's like this?
My truck has a drain plug, no draincock like the old style (is that what you mean??). Look for a tab on the bottom of the radiator on the driver's side. It just threads in and out.
there should be one there. check again. it will be a tab only. :duh:
04 plus dont have one
You can pull the plug out of the block to drain coolant
Dont not why but the petcock is not there
I'll be damned, I learn something new everyday. It seems gm is making where it is impossible to work on your own vehicle.Quote:
