I need the end connector off of a junk ypipe, from where the pipes merge to the end.
http://i17.photobucket.com/albums/b65/foggy_/ypipe.jpg
man i think i just threw mine away ill check tonight when i get home
I have a cat back of an 09 1500 with the MAX 6.2 you can have if you come get it. Not sure it's the same but it looks like it if the diameter is the same.
i know mine had a 3 1/2 ish inch diameter FWIW
it was either barely bigger or barely smaller than 3.5.......
But you can have the whole thing. And it comes with a life size muffler. Want me to cut off the end and mail it? Wrap the pipe with a string just behind the flange and mark it. Send me the OD. Also send the center to center dimension of the studs. If it's the same I'll cut it off and ship just the flange. Deal?
i just cut the cats off of my old ypipe and sold the cats... y pipe is yours 30 shipped...
PM returned.
How much of it do you need? I have one stock off a truck that I can cut off the end but it's really close to the split in pipes and might be kinda rough. Not sure if they're will be enough left to weld...but I could cut it up farther where the pipes are split. I'd need some PayPal to cover shipping....let me know.
BTW, the flange on the 6.2 exhaust I have is HUGE. 5.75" center to center on the studs and a 4" opening.
