need help please..
I was cruisin in town tonight, and I was just going thru some cars at idle speed, suddenly my truck start acting weird and a "engine power reduced" or something like that showed up in the screen, and the check engine sign.. I gave a little bit of gas and nothing.. truck is barely walking.. I parked and shut it off.. wait for a couple of seconds and started up again and drive back home acting normal but the check engine light still on.. what do you guys think that went wrong?
Check all the wires at the throttle body connector for broken inside the insulation. Common problem. You'll have to cut the tape off the wires and peel back the black plastic conduit. Pull test each wire from the connector to about four inches back. Look for one of the wires to stretch and the color of the insulation to turn wihite. This is where the copper inside is broken. Also check each wire at the terminal for poor crimp or broken right at the crimp. Also check the black with white stripe PCM ground wire from the large wiring harness at the back passenger side of the intake manifold down to where it bolts to the block between the intake and the wirewall. Pull on it pretty good to make sure it's not broken. This is the most commonly rodent chewed wire on these trucks. In rare cases the bolt holding it down is loose. If you still don't find anything, have the battery load tested. When the battery is a little weak it can still start the truck but the TACM and the PCM "wake up" at different times and do not communicate causing REP.
I checked all those wires and they where fine.. and drove my truck to the mechanic, and he wasnt there.. by the time I started up my truck again in the shop, the check engine dissapear.. a guy in the shop told me it might be a piece of dirt or trash on the gasoline that might get in my fuel injection system.. truck is running good now.. Hopefully it was a piece of dirt or something like he said..
Reduced engine power is caused by something related to the electric throttle not from fuel problems.
well, I checked all the cables that you told me and nothing seems to be wrong.. maybe there was something lose or something but truck is running good now.. thanks bud!!
my friend just had the same problem with his 07 chevy and it turnd out to be the fuel pump....do you run your truck all the way doen to empty alot??
his did the exact thing all of a sudden started running like crap pulled over turn the truck off and started back up and ran fine a little weil later id did it again
mine used to do the same thing then i found out my drives side tire was rubbing my wiring harness in half, fixed it now i dont have the problem anymore, im not saying that was the problem it may have just went away but it wouldnt hurt to take a look.
the time my truck did that, I was pretty low on gas.. maybe I will need to replace my stock pump to feed my 42lbs injectors and the nos shot.. and to prevent my truck from doing that..
Sounds like it is time for a tank flush, a fuel filter, and a Walbro 255....
