comp 918 springs (the good ones) or a comp credit??
I have a set of comp revised silver 918 springs, they have about 2500-3000 miles on them, all look fine and dandy. 125 shipped....OBO
I also talked to Comp, they will take them back and give a 189 dollar credit... I have my replacement springs lined up so I dont need anything... anyone what to save a little money that is going to be buying from comp soon?
Some more info...
COMP Cams® Beehive™ Valve Springs deliver increased valve train stability and a much lighter valve train. This is achieved with less spring pressure for better valve control and reduced weight of both the spring and the retainer. For street/strip applications, these valve springs are the best choice possible. Because of the unique Beehive™ design, the valve train can handle more rpm and more aggressive cam profiles for occasional bracket racing but still retain durability for street driving.
Engineered to fit stock heads with no machining, utilizing the stock valve seat and spring retainer.
# Designed for hydraulic roller cams
# .600” maximum lift, 1.290” O.D.
# Originally designed for LS1, LS2 and LS6 engines
