Drag wheels/tires
I'm looking for some track wheels/tires for my truck. After just buying a new set of tires for my 20s, I don't want to burn all the rubber off those so I'm looking for at least a DOT, maybe a slick. What are most you guys running out there? I can't figure anything out because my truck has a 2/4 lowering kit and the wheels are on 265/50/20s and that's a 30.5" tire.. so most likely I'll have to get a smaller front wheel too where my front end won't be a lot higher. Any advice is appreciated. Thanks
get some stock 16s and the hosier slicks. hook great, last, and are 28'' tall so wont look so bad on the truck. and they can be run tubeless. If it is a track only setup, go slicks. my :twocents:
for a boosted application DRs all the way. i run a 295/65/15 MT DRs. you can run 15s and they are cheaper then other size tires.
for skinnies you can run colorado spares. they are 16x4 and M&H makes the 27" front skinnies.
yeah just run what I run. looks good and hooks
nitto 555r most deff i got them in 305/35/20 hook real good
the stock 16 with slicks work well that what i used on the old truck i got the rims for free from a buddy that works at a dealer
i run four 305/45r18 nitto 555rs on some titan 5 spokes. they are about 28.8 inches tall
