Bearings
So the other day here in south dakota we got a pretty good amount of snow and it was pretty slick out. So i was driving in 4 wheel drive on my way to pull my friend out with my dads pick up i went to leave a stop light and i moved about an inch when the front end decided to lock up. Anyways to make this short i pulled the front diff out and apart only to find pieces of bearings and metal shavings. Anyways does anyone know where i can find a rebuild kit or something for this without going out and getting screwed over by a stealership. By the way the truck is a 2002 silverado 2500hd. Thanks in advance.
Travis
i posted this in the mechanical side but i thought i would try it out here.
you could try Proven Force in MN. Call the one in arden hills thets the one that stocks all the gear stuff
Proven Force Clutch and U-Joint - 3 Minnesota Locations
