I will be starting my swapped LQ4 single turbo and would like some help with the injector settings in HP Tuners. Thanks
what do you need? you need the IFR table numbers for 60lb injectors?
in hp tuners there is a conversion chart. you type in your injectors, then type in current fuel pressure, then type in new fuel pressure and it gives you the proper scale for injectors. if your return then your values will be same across the board
thank you!
your welcome, i also have a good value set for the 60s i currently use. if you need help with tune let me know. i can look over your file and logs
I will be hooking up the HP tuners up today or tomorrow and although I have been reading as much as I can about HP Tuners I still don't know exactly what to do (credits downloading tune etc.)
i just got the truck started on the first crank then i changed it to an sd tune and it wont start. i still need help with the 60lb injectors
thanks guys, Mean 05 i completely eliminated the MAF it has been permanently removed.
if you dont have SD fully then it wont work. in the Help section of HPtuners it has a procedure for you to use SD. if that doesnt work ill look over your tune if you need be.
there is no need to tune with maf at all to first start the tune. and since you completely eliminated the maf you just need to set the tune up correctly thats all.
