just bought a double din for my truck. need some help finding the right dash kit for it. radio is a pioneer avic d2. truck is an 06 RCSB non bose. TIA
dash kit is a metra 95-2003 and harness is a metra 70-2003 you will also need a antenna adpt it's a meta mdp-4 ok the harness you will have to run your own ign either got to the fuse box and tie into the wiper fuse or go to the column and tie into the pink wire not sure of the best or scoshe part numbers on the kit and harness hope this helps
FYI, I just put Nav in my Tahoe, GPS antenna works fine placed
on dash frame behind radio and UNDER dash pad.
Save much time, rather than mounting it outside somehow.
