Does anyone know if the front rotors and calipers off an 07 truck will fit an 03? I know their bigger but is everything else the same?
The rotors are bigger and will not fit under the stock '03 rim which is 16". Hence the 17" wheels. What wheels do you have?
Chris
22s. Would their be any modification to install?
If you are running 22s, you should do a big brake upgrade. Not a stock to new stock upgrade. Powerslot Cryos, SSBC Big Bite, Baer Decelarotors. I am missing some but you get the point. You would probably like the feel of it much better. Dont forget the stainless brake lines.
Chris
