In need of more power
06 Silverado
5.3L
Bone stock
I am considering cam, pulley, exhaust, etc.
Any recommendations for brands, specs, what works/what doesn't would be greatly appreciated.
Thanks, guys.
06 Silverado
5.3L
Bone stock
Thanks, guys.
well for starters is this your daily driver or track only truck. if its daily driver the cam choice will make a difference. A lot of people seem to like the Gm Hot cam, or i like my thunder racing cam as well, has lots of power and really pulls like crazy up top. you will most likely need springs and hardened pushrod's, so i bought a kit was the easiest way and got everything i needed. Get some electric fans going in there as well. Exhaust i wish i had gone with headers that had flanges on the end, i bought the pacesetters but since i have to worry about emissions i had to have cats welded in, ect. If you don't have to worry about emissions then you can get the ORY (off road y pipe) would be a seamless install.
check out the front page.. with the 100hp on a budget
daily driver.
currently plated as a MI truck but will have TX plates in april so emissions will be/are an issue
Go with a thunder racing 220 or something in the same area from TSP. I got a step down from the 220 which is the old man cam and i regret not going at least a little bigger every day. Like stated earlier get the kit. You will need it. LT headers are a good buy as well as efans. Get a tune more then anything if you dont have one. Nealson is a good buy because if you plan on doin alot more upgrades he does retunes for free i believe. I advise going ahead and picking up billet servos and a shift kit. Because a good cam and everything thats been stated will QUICKLY end the life of a tranny. Thats why mine is slipping and in need of a full rebuild because i cut corners and didnt install mine when virgil and tyler did the motor.
