How much will it lower my truck if I remove my overload spring?
The thickness of the spring. 1/2" at the most.
Better off buying 2'' drop shackles. They are cheap and easy to install. Look for used ones under $50
I already have the drop shackles but I want to go lower.
Get hangers .
Can you get hangers without shackles? But my reasoning for the overload spring is that it's free!!!
Put up a wanted add... Im sure somebody arround here has an extra set
I took my overload out and it dropped an inch but i needed traction bars afterwards
I might put an add up after I get my 4:10's and govloc. Cowl after removing the spring you lost traction?
