start-up/idle issues...imagine that?
start-up issues since new build install...
this is after ALOT of idle tuning...
LS1, Procharger P1SC, Patriot Stage III heads,
218/230 .605”/.604” 112LSA +3, longtubes
mornings...fires up on first turn over and usually catches itself and idles...
however, after several minutes of warming up @ idle, putting it in gear its fine but usually cuts off when I turn the wheel to exit the driveway...
rest of the day it MAY fire up on first turn over but will not catch itself and idle...
sometimes on the 3rd or 4th attempt it will catch if I don't decide to go ahead and pedal it...
if I pedal it for a little while, it idles fine...still wants to cut off when I start to leave the parking space though...this is after noticeably going into closed loop...
once I'm on the road...its all good...morning, noon or night...
tried adding more air at start-up...worked for a day or so...
tried adding a couple seconds to delay @ start-up...worked for a few starts, then right back to same issues after driving 15-20 minutes, parking and attempting to restart about 30 minutes later...
only SES code active is TPS performance range...I assume this is due to idle screw adjustments made during idle tuning...could this also be my catching @ start-up issue as well?
what specifically to I need to be looking at?
thanks in advance!
