just wondering, would an 85mm throttlebody bolt up and work properly with a 5.3l intake manifold
professional products 85mm comes with a spacer that go from 85mm to 78mm. I'm not sure if they sell it seperate.
Yeah, it will bolt up. If you get the p p it comes with the spacer.
would a p p throttle body be much better that a stock ported one
Would you gain anything going to a larger diameter TB if the intake is still the same size?
