Tranny Cooler
Just picked up a tranny cooler from out of a Eldorado, it a plate type cooler not sure of what the rating is, but wondered if it was a big enough cooler for my 4l80e? It's a stock T/C for now but will upgrade later. Also which of the lines are the supply from the Tranny?
It'll work but you'd benefit from a larger cooler. The supply line usually comes out the top of the radiator and the return goes in the bottom.
Thanks, I thought that i would put a gage inline. Hot in the top, return out of the bottom of the radiator, right? Which line coming from the tranny is the outlet? Also I think I read some where to have the aux cooler before the radiator, so it would maintain the temp from being to cool in the winter?
Found a link for return lines Cooler_Line
Is it better to run an external cooler, or use the one that is on the radiator? Or both?
When i get my swap together i was thinking about using a large external cooler and then maybe a radiator fan off of a motorcycle so that it would have it's own cooling system.
I was wondering if anyone else has used a setup like this?
