I just changed the transmission oil & filter,how much fluid
do I put in?
do I put in?
Start with 6 quarts. It will probally take 7 to 9. Start it up, put in R then D and recheck the fluid. Don't top it off until the fluid is fully up to temperature. Drive it and recheck it. When it gets close to full I only add 1/2 quart and then recheck it. You might have to put in and pull out the stick a bunch of times(wiping it off each time) to get a good reading as the fluid will keep dribbling down the fill tube. Don't ever overfill it. Good luck!
