Need Some Help
I am installing a 5.3 and a 4L60 combo into a 79 Jeep DJ5. I have modded the tube to look like a CJ5. I have also installed a three link on the rear with a watts link. Anyway I need to know what size the trans to block bolts are. Any help would be appreciated.
Metric 10mm x 1.5 pitch thread 40mm long, minimum thread length of 26mm.
Thanks. I will pick some up in the morning. All I have left to get is a 99-02 wiring harness and a alternator bracket.
Awesome--if that is all you have left, you are in GREAT shape. Good call on the rear suspension setup!
Good luck with the build--and ask as many questions as you want...
