cable throttle 2005 5.3 with Drive By Wire ECM
I have a 2005 5.3 from a GMC Savanna van that is factory cable throttle. I'm using it in a conversion project. Unfortunately it didn't come with a harness or ECM. I purchased a 2006 silverado harness and a 2004 avalanche ECM (service #12586242). Both are from drive by wire vehicles. I've modified the harness with the correct plugs on the throttle body for the TPS and IAC and connected those wires to the correct pins at the ECM as per the 2005 van wiring diagram. The guy that is doing the reprogramming my ECM has never converted form DBW to cable throttle. My question is can he use the flash from a DBW vehicle (which is every truck but the van) and just delete the electronic throttle control or does he have to use the flash from a van with cable throttle? Has anyone done this before and can you tell me what's involved? Thanks in advance.
