Trans wiring help... Experts/Techs nneded...
I have transplanted a LQ4 6.0 liter out of a 2000 GMC 2500 4x4 into my 1991 GMC Syclone. I have the original wiring harness and computer hooked up. I am using HP Tuners for tuning also. The Engine is hooked up to my 1995-1996 built 4L80E trans. I am not using the original 4L80E trans the engine came with in this build. I do not have it. Anyway, I thought I had everything hooke dup correct but the trans is in 2nd gear and will not shift while driving. I guess it is in default mode. I have checked all the wiring from the main connector and the two little ones at the trans and they are all fine. I am missing something little I am sure but can not figure it out. I see in the pin out that there are like 4 other wires at the ECM that are not being used. Labeled like PRND A Input, PRND P Input, TCC Brake switch, PRND B Input. Anyway, I was thinking the 2000 truck it came out of must have another sensor elsewhere I do not have or something like that.
Any ideas?
It will go right into Reverse and drive without a problem. Just will not change gears while driving, stays in 2nd. :(
Thanks
Will
