ok so im gunna put this on my LQ9 can any 1 tell me if the stock body is drive by wire or cable? and if it is wire can i switch it to a cable throttle body?
THX
Will
THX
Will
I did an 86 swap can't help with the 4x4 Q's but the fuel stuff should be very easy on an 87. you will have to change out the E pump to get your pressure up. check the posts it's in here. I ran an ext. pump but plan to change to an 87 tank set up with new pumps to get rid of the hummmmmmmm
