P0443? and A/C problems
Hey people i just finished my ls1 swap and im now throwing a p0443 dtc code and my a/c doesnt work but, when i turn on the a/c i can feel the trucks rpm's change when the a/c compressor turns on but the air is hot as hell. Someone told me it may not work because i changed the ground on the back of the block? Is this true any help would be nice Thanks
Brandon
Well sir, the P0443 Indicates something is affecting your evaporative emission purge soleniod. The fact due to the A/C not blowing cold means either your low on refrigerant or one of your air mix door is fully stuck in the hot position for the heater. I had this problem with a 99 GMC Sierra SL and it was the blender door, despite having sufficient refrigerant charge. you see this OBD II system is designed to monitor emission levels and optimize your fuel economy and doesnt monitor A/C with a P code. P code is for powertrain, and if a trouble code is produced for an A/C blowing hot or whatever, it will be a B code which may or may not turn on a "check engine" light which means a body control module fault code, which can monitor suspensions, power accessories, ABS, electrical faults and stuff like that. The OBD System is very sophiscated and yet tricky. Anyway that ground wire doesnt has anything to do with the A/C not blowing.
GearChatter.com :: View topic - DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control
Where is this blender door? I think that is my problem. How can i tell if its not working? Thanks alot
Brandon
