has anyone noticed a slightly rough running engine with ngk tr6 plugs?
Im trying to decide if my slight shake at idle is normal. seems to be running on all cylinders cause it will miss if you disconnect any coil. What else could i look for?
Mine runs a little ruff. not too bad bud you can feel it more than hear it... Cause these are colder plugs... If it bothers you Ive been told that if you tune the idle to about 700-750 you wont notice it--- Edit: also change the plugs every oil change. Or at least check them.
Someone else was asking about them a little while back.
http://www.ls1truck.com/forums/mecha...k-sputter.html
water pump low on water??
