Originally Posted by
americanthunder
I would say a nice tranny cooler would make a big difference, if the truck runs and shifts fine i wouldn't worry about any damage. I had a truck when i used to beat on it it would shift sloppy, put a tranny cooler in and i never had a problem again. The other thing i would check is make sure your brakes are not sticking. Next time you smell the smell walk around the truck and look at all four rotors (or drums) you'll be able to tell if they are hot, they will be bluish you can also spit on your rotor and if it instantly boils and evaporates chances are that is your problem! 90k is enough for silly things like that to start happening.. just a thought i've had it happen so check it out
