what all would i need other than motors tranny and wiring to drop a 6.0 LQ4 in a 96 silvy? where can i get parts, also how hard is wiring?
HAHAHAHA ITS ALREADY HAPPENING!! before you know it man your plans will do a 360 and youll be going gen III join the club they did it to me to hahah!
You'll need motor mount/adapters(carshopinc, TransDapt, or S&P). You may need different exhaust manifolds depending on which ones you have. I'm not sure if your stock radiator will work for you, I ended up keeping mine and just using some universal radiator hoses. I think Allen(Nelson Performance) does wiring harnesses aswell as Speartech and Painless. I hope that helps some. Good luck.
if this helps by the time im done mine will probably cost between 5 and 6 grand but im doinin it up...
Copy cat :LOL:
but mine is a LQ9
