Im swapping a fairly new set of #317 heads on my 6.0
Do I need new head bolts? Im gonna use new head gaskets
And would it be a good time to install LS6 springs? Even though Im not changing cams yet!!
yes you will need new bolts, the stock ones are torque to yield and one time use only. Also if your not putting in a bigger cam yet, then i wouldnt mess with the springs, its easy enought to change them later. But LS6 springs might be ok with the stock cam, im not sure.
