what will i need to make this work ???? want to keep the SFI
You'll need to order this intake and that's all unless you want to add a little tuning but it will run fine without tuning, I've done quite a few of these.
12496821, GM Performance Parts MANIFOLD
hey........that looks pretty good!!! thanks. But i was wanting to stay with the orginal intake for the vortec motor. individual injectors for each cylinder. I know someone has to make the harness for this to hook everything up. or will i have to use the computer off of the 97 to make this work????:burnrub:
You'll need a newer computer for the injectors to work. I'd keep it simple and go with the TB intake. You won't gain going with the vortec SFI, just looks.
thanks............I believe your right, lot less headache
