I am reading about the P&P throttle body's. What is the bypass i keep reading about? What does it do?
yeah whats the bypass?
theyre is alot of write ups about this .basiccally from the factory they run a coolant line through the tb.it keeps the tb from freezing,up in cold weather so if you live in the south no worries. so if you unhook /bypass ,it helps keep the intake temp cooler /tb hence more hp so it is a free upgrade so mite as well do it .just unhook the line on the left of tb and the right of tb .and attach them together with a fitting and clamp them together .good luck i hope it helps.
First off, I'll say I did this and it's stupidly simple. Second off, I'll say I did it and it was stupidly ineffective.
lol...you can do it but it's not going to give you any noticeable gains. Re-routing the line is going to reduce IAT's enough (if at all) to make it worth it.
gotcha, one more thing is the tb worth it?
Porting it? Yes - without a doubt. Contact Billy at TRT (817-703-3750).
I am with Moze...TB bypass mod is free and sounds like a good idea, but no real noticeable gains. You can either port your stock TB, or do a 80mm TB. My 80mm BBK TB is freaking awesome. I noticed a pretty big power increase when I installed mine--but then again, I did the TB and e-fans at the same time...
nice, thanks for the info, i think the next mods are going to be cam, springs and all, stall, and TB. I need gears and a LSD.
Yea i did the whole bypass thing too you'll need a 3/8 fitting 1/4 will work but its hell getting it on, but i didnt notice anything but even if its one hp its more than i had. My buddy just put an 80mm bbk on his 05 Z71 it worked so well that i ordered mine the next day. When i get it ill let you know.
http://i61.photobucket.com/albums/h4.../BUTTERFLY.jpg
2005 joe gibbs, k&n intake, mass air, hypertech, corsa, 4:10 gears
