Custom front mount single turbo setup for sale
I’m seriously debating changing my turbo setup to twins so my front mount single setup is up for sale. I built the setup myself; all piping is .065” thick 304 stainless from Stainlessworks. The manifold flanges are from them as well and are 3/8” thick.
Asking $2499 obo Shipped in the Continental US
Open to reasonable offers :cheers:
Garrett GT4294 turbo
TurboByGarrett.com - Catalog
1.15 A/R turbine housing, probably less than 20 street miles and 8 ¼ mile track passes at 5.5 psi (new to tuning, the Chevelle ran a 14.05 @ 105 mph leaving off idle with a dismal 2.488s 60’, internally stock LQ4, stock 4L80E, 1600rpm converter, 3.73 rear gear, 26” street tires)
T4 flange turbine housing 4” V band turbine outlet
5” compressor inlet and 3” V band compressor outlet
Tial 44mm v-band flange waste gate 11 psi spring
Manifold to turbo piping is 2.5”
Manifold flanges are 3/8” thick stainless steel
Downpipe is 3.5” and has two O2 sensor bungs
K&N air filter
Stainless 48” flex radiator hose
Oil supply and drain lines stainless steel braided hose, aluminum AN fittings
Support bracket for mounting turbo to alternator/power steering bracket
***Does not come with cold side piping, intercooler or bov***
***If I didn't list it above, it does not come with the package***
I’m not sure how I would ship the downpipe as it is; I would probably have to cut it into two pieces, but should be easy to reassemble.
I’m fairly certain that this will fit on a fullsize truck and took a couple of pics with a measuring tape for reference. If you need any additional measurements or pictures, just let me know.
If you want to see what this size turbo is really capable of, do a search for CurtD on performancetrucks.net…he has one on his truck with a built 5.3L running 12.0 @ 120 mph, making 619 rwhp and 657 ftlb PerformanceTrucks.net Forums - Dynoed today
http://i37.photobucket.com/albums/e5...Picture543.jpg
http://i37.photobucket.com/albums/e5...Picture547.jpg
http://i37.photobucket.com/albums/e5...Picture542.jpg
More pics can be seen here:
Picture548.jpg - Image - Photobucket - Video and Image Hosting
Picture551.jpg - Image - Photobucket - Video and Image Hosting
Picture555.jpg - Image - Photobucket - Video and Image Hosting
Picture553.jpg - Image - Photobucket - Video and Image Hosting
Picture556.jpg - Image - Photobucket - Video and Image Hosting
Picture554.jpg - Image - Photobucket - Video and Image Hosting
Picture545.jpg - Image - Photobucket - Video and Image Hosting
