sorry for the rehash
My fuel pump is rated for 55 -62 psi. I am getting 55 psi fuel pressure through the regulator. Am i using a fuel pump that is a little weak ( meaning should I get one that has a higher rated psi) or is it more likely that I am not getting enough electric current to the new pump I have installed?
Thanks
Thats about all I get out of mine. You may have a counterfeit pump.
Then again I might have a fake also.
so does your engine run a little lean as a result or are your running ok?
Thanks
