Power steering fluid
I remember the older GM vehicles would use Dexron II for PS fluid.
Ref: '02 f-body LS1 in a '92 2wd.
Does the pump on the LS1 use the same???
I bought a non designated fluid and the truck is steering heavy. The fluid is heavier than the Dexron II. I also have a wider tire now that will slow it a bit but shouldn't be this much.
I still used ATF in the Fbody pump for my 92/93 trucks. Steering gets heavy when the belts slip or the idle is too low.
Think I'll flush and switch over to ATF.
No belt squeal, and is also heavy under way, so the idle is up.
THX
Red,
What is the dia of your air filter intake duct?
